The Idea to project conversion process fails with the following error in the UI:
com.niku.union.odf.exception.ODFValidationException: System error. Contact system administrator.
What can be the cause?
Could be caused due to various reasons. Check the bg-ca.log to narrow down upon the exact cause.
Some examples:
Sample bg-ca.log extracts:
Complete error stack of the ODFValidationException:
ERROR 2022-03-28 10:04:37,968 [Action Execution Pipeline 0 (tenant=clarity)] utilities.BpmErrors (clarity:user:session:none) BpmErrors::getExceptionTrace(String arg) => com.niku.union.odf.exception.ODFValidationException: System error. Contact system administrator. at com.niku.odf.object.Utils.execService(Utils.java:226) at com.niku.odf.object.Utils.execService(Utils.java:284)
Just before that:
ERROR 2022-03-28 10:04:37,963 [Action Execution Pipeline 0 (tenant=clarity)] niku.xql2 (clarity:user:session:none) Internal Processing exceptioncom.niku.dms.util.DMSException: Could not retrieve file from file store. at com.niku.dms.util.FileUtil.readBinaryFile(FileUtil.java:621) at com.niku.dms.util.FileUtil.retrieveFileContentsFromFileSystem(FileUtil.java:79) at com.niku.dms.util.FileUtil.retrieveFileData(FileUtil.java:63) at com.niku.odf.object.Utils.addAttachmentToObject(Utils.java:3612) at com.niku.odf.object.Utils.addAttachmentToObject(Utils.java:3587)
Take action based on the exact cause determined from the bg-ca.log.
For example:
