ALERT: Some images may not load properly within the Knowledge Base Article. If you see a broken image, please right-click and select 'Open image in a new tab'. We apologize for this inconvenience.
Physical Node Power Supply Warning PAM-CMN-2007
Article ID: 237586
CA Privileged Access Manager (PAM)
N/A
Release : All
Component : Any PAM hardware appliance
Steps to perform:
Turn OFF the PAM appliance
Reseat the far right PSU
Turn ON the appliance and test.
If the same issue persist turn OFF the appliance and remove the PSU/s
Swap PSU/s and test
If the replaced PSU shows bad we have to replace it.
