Automation Point connect to AS/400 systems using TN5250 protocol
Article ID: 23682
Updated On: 08-13-2024
Automation Point
Can  Automation Point connect to AS/400 systems using the TN5250 protocol ?
Automation Point provides TN5250 protocol support. You could use TN3270 or TN5250 connections to connect to a AS/400 system. Since TN5250 is a native protocol for i5/OS Operating System, the recommendation is to use TN5250 as the connection protocol.
You can find additional information at our Tech Docs Portal website.
