Under the Utilities section of NetMaster MTC-NM there is a drop down panel which allows one to specify more Lines returned and Wait time. These initially are set to 100 lines and 10 seconds.
Is there a way to lower them to 2000 lines and 5 seconds, instead of having to change them every time we bring this page up?
Release : 12.2
Component : NetMaster Network Management for TCP/IP
Those defaults are being set each time that page is loaded, and there is no ability to override at initial load.
Given that MTC-NM is being replaced by our new WEB Portal, this will not be changing.
The newer Web Portal works more like a terminal and has a higher line limit.
