Fault Correlation Engine + Relationship_services probes not running anymore on Primary Hub
Article ID: 235949
Why Fault Correlation Engine + Relationship_services probes not running anymore on Primary Hub -  red state
Release : 20.3
Component : UIM - RELATIONSHIP_SERVICES
Basically Topology and Root Cause Analysis are NO LONGER SUPPORTED FEATURES BY UIM since new UIM 20.x versions.
It was replaced by a new Broadcom Product named DX OI
https://techdocs.broadcom.com/us/en/ca-enterprise-software/it-operations-management/digital-operational-intelligence/20-2.html
EOS announcement:
https://support.broadcom.com/web/ecx/support-content-notification/-/external/content/release-announcements/CA-Unified-Infrastructure-Management-Product-Components-End-of-Service-Announcement/7238
Just need to Delete this probes from your Hub
