Duplicating a ressource does not work inside a BV
Article ID: 235656
Automic Dollar Universe
When attempting to Duplicate a Resource (File/Logical etc.) inside a Business View the object is created but not added to the BV.
After using the right-click on an existing BV, the duplication screen is opened and the duplicate can be created. However, when clicking Save and Close the duplicated object is not visible inside the BV.
After a refresh of the list of Resources, it can be added.
Release : 6.10 Component : Univiewer Console
This is a bug.
Solution:
Update to a fix version listed below or a newer version if available.
Fix version: Component(s): Univiewer
Dollar.Universe v6.10.101 -  Available
Dollar Universe v7.00.01 -  Available
