Non-default MySql users cause problems with 21.2.8 NetOps Upgrade
Article ID: 235567
CA Performance Management Network Observability
The upgrade to DX NetOps Performance Management version 21.2.8 comes with a MySql upgrade from version 5.7 to version 8.0.
The upgrade expects to ONLY see 2 root and 2 netqos named users present per a default installation.
If there are extra root or netqos named users present, they will prevent the upgrade from running.
The following are the only 2 root, and only 2 netqos users, that can be present during the upgrade run. If any other root or netqos named uses are present they must be removed prior to running the upgrade.
NOTE: Default path shown. Enter password when prompted when running this command on your system.
[root@PC_Portal ~]# /opt/CA/MySql/bin/mysql -uroot -p -e "select user,host from mysql.user where user in ('root','netqos');"
Enter password:
| user   | host      |
| netqos | %         |
| root   | %         |
| netqos | localhost |
| root   | localhost |
[root@PC_Portal ~]#
All DX NetOps Performance Management PC Portal releases upgrading to 21.2.8 and newer releases
Upgrade to 21.2.8 and MySql 8.0 requires only the 2 default root and 2 default netqos users present during upgrade run.
Take the following steps to remove the extra users.
Default paths shown. Enter passwords when prompted.
  1. Open a terminal to the PC Portal CLI.
  2. Open a MySql connection using:
    • /opt/CA/MySql/bin/mysql -uroot -p
  3. Run the following to list out all root and netqos named users.
      • select user,host from mysql.user where user in ('root','netqos');
    • Using the "user@host" context we should only see two root and two netqos users as follows:
      • root@localhost
      • root@%
      • netqos@localhost
      • netqos@%
    • Any other users seen don't belong and need to be deleted.
  4. To remove errant users we'd run:
    • drop user '<user>@<host>'
Sample output with three root user entries that require removal. The 'missing' host entry is blacked out. It has a hostname as a value.
We see we need to remove users:
To remove those users we'd run the following query commands.
  • drop user 'root'@'hostname';
  • drop user 'root'@'127.0.0.1';
  • drop user 'root'@'::1';
