ACF2 Certificate problem with TN3270 and AT-TLS: EZD1287I TTLS Error RC: 6 Initial Handshake and EZZ6035I RCODE: 1030-01
Article ID: 232812
ACF2 for z/OS
Upgrading z/OS 2.3 to 2.5 and converting from TN3270 built in SSL to using AT-TLS for TN3270 sessions.  Self-signed certificate is used and TCPIP errors show SSL handshake and EZZ6035I RCODE: 1030-01  TTLS Ioctl failed for query or init HS error.
EZZ6034I TN3270 CONN 000000xx LU **N/A**  ACCEPTED   23001 191
  IP..PORT: ##.##.###.###..####
CAS2205I REQUEST=R_datalib       ,EXIT=PRE ,RC=N/A
CAS2206I USER=xxxx  ,UID=0         ,GROUP=xxgrp  ,GID=####
CAS2206I Function=DataGetFirst  ,Userid=xxxx
CAS2206I Ring Name=RINGNAME
CAS2206I Usage=Personal len=055C     ptr=000000## 875230F0
CAS2206I Label=CertLabel
CAS2206I Subj DN   len=0000003E ptr=000000## 87524930
CAS2206I Certificate Owner xxxx
CAS2206I Recd id len=00000037 Val=00.CN=xxxx,OU=ABC,O=ABC Bank,
CAS2205I REQUEST=R_datalib       ,EXIT=POST,RC=0/0:0
CAS2206I Function=DataGetNext   ,Userid=xxxx
CAS2205I REQUEST=R_datalib       ,EXIT=POST,RC=8/8:44
CAS2206I Function=DataAbortQuery,Userid=xxxx
CAS2206I Function=GetUpdateCode ,Userid=xxxx
CAS2206I Ring Sequence #=00000003
EZD1287I TTLS Error RC:    6 Initial Handshake 216
  LOCAL: ##.#.###.#..#####
  REMOTE: ##.##.###.###..#####
  JOBNAME: jobName RULE: ruleName
  USERID: xxxx GRPID: 0000000# ENVID: 0000000# CONNID: 000000##
EZZ6035I TN3270 DEBUG CONN   DETAIL 217
  IP..PORT: ##.##.###.###..#####
  CONN: 000000##  LU:          MOD: EZBTTXPL
  RCODE: 1030-01  TTLS Ioctl failed for query or init HS.
  PARM1: FFFFFFFF PARM2: 00000464 PARM3: 77B77221
EZZ6034I xxxx CONN 000000## LU **N/A**  CONN DROP  ERR 1030 218
  IP..PORT: ##.##.###.###..#####                             EZBTTXPL
Release : 16.0
Component : ACF2 for z/OS
The self signed certificate needs to have a private key and connected to keyring using DEFAULT(certname) specified to fix EZD1287I SSL handshake error. Sample commands to create self signed certificate and connect certificate to keyring using DEFAULT are shown below:
SET P(USER) DIV(CERTDATA)
GENCERT xxxx.CERT SUBJ(CN='xxxx' OU='ABC' O='ABC Bank' L='CityName' S='AB' C=xx) LABEL(CertLabel)
SET PROFILE(USER) DIVISION(KEYRING)
CONNECT CERTDATA(xxxx.CERT) KEYRING(xxxx.KEYRING) DEFAULT(xxxx.CERT)
F ACF2,REBUILD(USR),CLASS(P)
PTFs LU03440 and LU01752 fix EZZ6035I RCODE: 1030-01  TTLS Ioctl failed for query or init HS error message.
