Help using Global Temp Variables - When are variables with GLVTEMPx deleted?
Article ID: 232208
OPS/MVS Event Management & Automation
Variables with stems GLVTEMPn like GLVTEMP1 are temporary variables. When will they be deleted after they are created?
Release : 14.0
Component :
From documentation:
"A global variable with a stem of GLOBAL. or GLOBALx is permanently saved across IPLs or restarts of CA OPS/MVS. A global variable with a stem of GLVTEMPx is saved only while CA OPS/MVS is active."
So GLVTEMPx variables will be deleted if OPSMAIN is recycled.
Refer to the Section "Global Variable Basics and OPS/REXX" in the "Using Global Variables" chapter of the OPS/MVS Event Management and Automation Using manual.
