MCS Recon not running on Passive robots
Article ID: 230933
MCS Reconciliation, via mcs_recon probe doesn't seem to be running correctly for Passive robots
mon_config.service.recon.log.1 shows:
Errors:
The 'probelist' key was not found in getrobots response for robot xxxx
Release : 20.3
Component : UIM - MON_CONFIG_SERVICE
MCS_RECON is nto supported on Passive robots
MCS_RECON is used for active robots as these robots sends data to primary hub whenever robots receive the data but passive robots are not in continuous sync with primary hub, passive robots sends data only when the hub request the data to passive robots.
So mcs recon will give communication errors when we try to run it on passive robots. Usually MCS_RECON is used to run active robots.
