We are having some problems with node.js probes communicating with their respective Infrastructure agent. These apps are deployed on aws-eks. The applications are deployed as a pod containing the node.js application container (with the node.js probe installed) and the Infrastructure agent deployed as a sidecar container also within that pod.
The connection between the probe and agent seems sporadic and inconsistent with no metric telemetry relayed.
The log show this message
Probe has disabled runtime metrics reporting because it could not validate Collector Agent version. Please check probe compatibility guide.
Release : SAAS
Component : Integration with APM
Old CA-APM-Probe 1.10.84
Customer was using an old probe.
They implemented the CA-APM-Probe 2.0.3 and it was able to communicate with the APMIA.
If customer is using Node.js 12.15.0 and APMIA 21.6.0.26, they can use any of the ca-apm-probe versions (1.11.x or 2.0.3) but if they are using http protocol then they should use 2.0.3
