Robot experiencing issue starting and updating.
Article ID: 229855
Robot is failing to start.  Nimbus.log is showing the following:
controller.log is not getting updated.
Nimbus: Ready to begin: starting controller
Nimbus: 'controller' FAILED to start (193)
Nimbus: Started
Release : 20.3
Component : UIM - ROBOT
Multiple robots installed on the server.  The ports are conflicting and preventing the services from starting up properly.
  1. uninstall the robot
  2. look for any nimsoft directories on the C: or other drives to clean off
  3. make sure that there are no processes listening on ports 48000-48003 (netstat -aof | findstr :48000)
  4. Once that is confirmed, re-install the robot
