Changing default port for connection to the Internet Gateway
Article ID: 229744
IT Management Suite
By default, port 443 is the port used to communicate between the Client Machine in CEM mode and the Internet Gateway.
Can this port be changed? Are there any other ports that can be used? For example, let's say we want to use port 550 in place of 443 can this be done?
ITMS 8.5, 8.6
By default, all requests are forwarded from the default HTTPS port 443 on the gateway when coming from the Client machines in CEM mode to port 4726 on the SMP Server.
Yes, you can use a different open port if you want but we usually recommend keeping the standard ports to facilitate future troubleshooting.
To configure the Internet gateway using the Symantec Management Platform Internet Gateway Configuration wizard if you are setting up a new Internet Gateway:
  1. On the Internet Gateway computer, launch the Symantec Internet Gateway Manager, from the General tab start the "SMP Internet Gateway Setup" and this starts the Symantec Management Platform Internet Gateway Configuration wizard. This starts on the Internet Gateway Setup so click "Next" once and this will take you to the IP Address and Ports page. On this IP Addresses and Ports page, specify the appropriate IP address and Ports, and then click "Next".  The following screenshot shows this:
  2. On the Cloud-enabled Management Settings page, found in the SMP Console under Settings > Notification Server> Cloud-Enabled Management > Policy > Cloud-enabled Management Settings, specify the port to be used to connect to the Internet Gateway. If it is a new Internet Gateway, click on Add gateway and specify the desired port. If it is an existing Gateway, just Edit the current reference as shown here:
By default, the port for incoming connections is 443. However, you can specify a different port number if necessary. All of the specified port numbers must be TCP ports (these are numbered 1-65535).
If you already have an Internet Gateway, you can make the port change under the General tab in the Symantec Management Platform Internet Gateway Manager as shown here:
You should use the IP address of the Internet Gateway computer. You can specify only one port number and only one IP address. If you choose to use all available IP addresses, the same port number is used for all IP addresses.
If you decide to change the default external port (from the client machine to the Internet Gateway), as mentioned you will need to update the Cloud-enabled Management Settings page the SMP Console under Settings > Notification Server> Cloud-Enabled Management > Policy > Cloud-enabled Management Settings to update the CEM policy so the clients can be aware of that new port.
Answer based on current documentation: CEM Whitepaper
