observing metric gaps issue for a java agent
Article ID: 229545
APM
We are using APM SAAS environment to monitor java application.
One of the WebSphere Java agent is reporting gaps in APM UI for almost all metrics.
We are not seeing this issue with other agents. Just this one so far.  Gaps are intermittent.
Release : 20.2
Component : APM Agent
Recycle of the agent resolved this issue.
