Logon to Automic system is not possible.
Article ID: 229531
CA Automic Workload Automation - Automation Engine
Users cannot logon via the AWI. The Service manager Dialog shows certain processes having connections and others do not.
Release : 12.3
Component : AUTOMATION ENGINE
Data inconsistency.
Once all the server processes were shut down the PWP process still remained in the table MQSRV. Once this entry was removed and the server processes were started all of them showed connections in the Service Manager Dialog. The logon through the AWI was also possible again.
If you are experiencing a behavior like that please contact Support.
