Yesterday we could perform recommended upgrade on open case 32917086 (Upgrade all hubs to hub_9.33_HF1.zip and Upgrade all hub robots to robot_update_9.33_HF6.zip).
Everything is working fine but this morning checked that data engine queue have lot of data queued vs sent data.
Refreshing some times later, seems like working properly:
Is this a normal behavior? Queue takes some time to stabilize?
Release : 20.3
Component : UIM - DATA_ENGINE
- data_engine configuration
data_engine configuration updated with best practice settings.
Settings changed:
