During the execution of DISK job CCUWJCL(DBMOVE) to enlarge or move the Datacom DB, the job can fail with the below messages:
11.00.34 JOB35447 IEF196I ACF9CCCD USERID A328352 IS ASSIGNED TO THIS JOB - SMDBMOVE
11.00.34 JOB35447 IEF861I FOLLOWING RESERVED DATA SET NAMES UNAVAILABLE TO SMDBMOVE
11.00.34 JOB35447 IEF863I DSN = DMS.META.T0.DB.DMS650 SMDBMOVE RC = 04 RSN = 00000000 FROM SERVICE ENQ
11.00.34 JOB35447 IEF863I DSN = DMS.META.T0.DB.IXX650 SMDBMOVE RC = 04 RSN = 00000000 FROM SERVICE ENQ
11.00.34 JOB35447 *IEF099I JOB SMDBMOVE WAITING FOR DATA SETS
What is causing the problem and how to fix it.
Release :
Component : Disk Backup and Restore
The above messages are caused by an MVS ENQ problem on the IXX and DMS datasets because in the same job there are conflicting actions against the same Datacom DB (it tries to close the DB and allocate with DISP=NEW a dataset which is currently managed by Datacom).
In order to avoid any ENQ problem the Best Practice is to split the DBMOVE job in 2 subsequent jobs as follows:
JOB1 - executing the 1st and 2nd step of DBMOVE job (CLOSE/BACKUP-RENAME)
JOB2 - executing the 3rd and 4th step of DBMOVE job (ALLOC - LOAD/OPEN)
Here the two sample jobs we suggest to execute:
JOB1 :
//DBMOVE01 JOB (...),MSGCLASS=T,
// REGION=0K,CLASS=P1
//* THIS JOB IS INTENDED TO BE USED IF YOU NEED TO MOVE A *
//* CA DISK DATABASE TO ANOTHER PACK(S) OR IF YOU NEED TO *
//* COPY THE DATABASE TO A LARGER ALLOCATION. *
//* GENERALLY THIS WILL BE USED AT SUPPORT'S REQUEST. *
//* CA DISK DATABASE MUST BE CLOSED BEFORE THIS JOB CAN BE RUN. *
//* ALL CA DISK TASKS USING THE DATABASE MUST BE QUIESCED. *
//* --- THE MUF MUST BE UP TO RUN THIS JOB. --- *
//* THE JOB CONTAINS FOUR STEPS AND MUST BE SPLITTED INTO 2 JOBS *
//* OTHERWISE YOU WILL FACE ENQUEUE ISSUES. *
//* ADJUST THE REQUESTED DBID: *
//* 1. JOB: *
//* BACKUP - BACKS UP THE DATABASE IN NATIVE SEQUENCE *
//* RENAME - RENAMES EXISTING DATA AREAS *
//* 2. JOB: *
//* ALLOC - ALLOCATES NEW DATA SETS *
//* LOAD - RELOADS THE DATABASE *
//* EXAMINE THE DATA AREA ALLOCATION SIZES TO BE SURE THEY ARE *
//* AT LEAST AS LARGE AS THE CURRENT ALLOCATIONS. YOU MAY INCREASE *
//* THE SIZE OF ANY OF THE DATA AREAS. *
//BACKUP EXEC PGM=DBUTLTY,REGION=4M
//SYSPRINT DD SYSOUT=*
//DATAOUT DD DISP=(NEW,CATLG,DELETE),SPACE=(CYL,(500,100),RLSE),
// DSN=DMS.SKA.P0.DB.DMS650.BACK(+1)
//SYSIN DD *
SET OPTION1=ON-ERROR-CONTINUE
ACCESS STATUS=OFF,DBID=650,USERS=WAIT
COMM OPTION=CLOSE,DBID=650
BACKUP DBID=650,DDNAME=DATAOUT,SEQBUFS=128,SEQ=NATIVE
//* RENAME EXISTING DATA AREAS
//RENAME EXEC PGM=IDCAMS,REGION=4M
//SYSOUT DD SYSOUT=*
//SYSUDUMP DD SYSOUT=*
//SYSIN DD *
ALTER DMS.META.T0.DB.IXX650 -
NEWNAME(DMS.META.T0.DB.IXX650.OLD)
ALTER DMS.META.T0.DB.DMS650 -
NEWNAME(DMS.META.T0.DB.DMS650.OLD)
JOB2:
//DBMOVE02 JOB (..),MSGCLASS=T,
//* ALLOCATE NEW DATA AND INDEX AREAS
//ALLOC EXEC PGM=IEFBR14
//DMS650 DD DSN=DMS.META.T0.DB.DMS650,
// DISP=(,CATLG,DELETE),
// UNIT=SYSDA,MGMTCLAS=SUB#U099,
// SPACE=(CYL,(200,50))
//IXX650 DD DSN=DMS.META.T0.DB.IXX650,
// SPACE=(CYL,(100,20))
//LOAD EXEC PGM=DBUTLTY,REGION=0M,MEMLIMIT=NOLIMIT,
// COND=(0,LT)
//SORTMSG DD SYSOUT=*
//SORTDIAG DD SYSOUT=*
//DATAIN DD DISP=(OLD,KEEP),DSN=DMS.SKA.P0.DB.DMS650.BACK(0)
//SYSIN DD *
INIT AREA=IXX,DBID=650
INIT AREA=DMS,DBID=650
LOAD DBID=650,FORMAT=BACKUP,DDNAME=DATAIN,
KBYTES=98,SORT=9999999,OPTIMIZE=YES,OPTION1='(I)',
SORTDD=SORTMSG,SORTDFLT=YES,SORTWK=7
ACCESS STATUS=WRITE,DBID=650
The additional changes evidenced in green are introduced to increase the performance of the LOAD step, according to the knowledge article "Calculate the SORTWK space needed on CA Datacom DBUTLTY LOAD and RETIX",
