Metric data flow from SYSVIEW was not flowing to the MOI appliance despite MOI, Message Service Server (MSS), zDataMover, and SYSVIEW being up and functional with no errors being displayed.
Release : 2.0.*
Component : MF OPERATIONAL INTELLIGENCE
Ensure that the following adapter is ENABLED in the Message Service Server member ZMSENVT in the CAW0OPTV data set:
ZDM_ADAPTER_ACTIVATION_STATUS=ENABLED
Valid values for activation status are: ENABLED or DISABLED
Any other value entered besides the valid values above will result in the adapter being DISABLED.
If the ZDM_ADAPTER_ACTIVATION_STATUS=DISABLED is displayed in the MSS STC log, then no data flow to the MOI appliance will occur from SYSVIEW or any other product that communicates using the zDataMover.
