MDB Database connection problem while SQL is up and running
Article ID: 228326
CA IT Asset Manager CA IT Asset Manager Asset Portfolio Management CA Service Management - Asset Portfolio Management ASSET PORTFOLIO MGMT- SERVER CA Service Desk Manager CA Service Management - Service Desk Manager CA Service Catalog Process Automation Manager CA Process Automation Base
During startup of the CA Service Desk service, even though SQL Server is known to be up and running, CA SDM cannot connect to the database server
Errors in STDLOG:
SDM-SERVER pdm_d_mgr               2440 SIGNIFICANT  ntservice.c            311 Command return non-zero exit code. Command: sql_check_db  -c. Exit Code: 99
CHECKDB log shows the following error:
AHD50063:Unable to access pri table
Manually running the command "sql_check_db -c" from NX_ROOT\bin results in the same error as above.
stdlog and checkdb logs are kept in the SDM install directory's log directory.
CA Service Desk Manager 17.1 and higher
SQL Server DBMS
The mdbadmin user defined in SQL Server does not have its permissions set correctly
Additionally, the mdbadmin password may have been reset at the SQL Server level without SDM pdm_configure executed to update the change.
If the determination is made that the mdbadmin credentials have been changed, run pdm_configure on each of the SDM Servers within the affected environment to update the mdbadmin password.
Additionally, one may review the following to confirm the mdbadmin user configuration.
Access the SQL Server Management Studio, logging into the given database server as the 'sa' user or as a user with sa level privileges.
Note:  Use a separate login with sa level privileges over the DB Server.  Do not use the mdbadmin user for this purpose.
Access the given SQL Server and under Security -> Logins, choose the mdbadmin user, right click and select "Properties"
Under the "General" section, the mdbadmin should have the default database set to mdb
Under User Mapping, select the mdb database, confirm that the user selected is "mdbadmin", that the Default Schema is "dbo" and that the Database role membership listing has the correct role memberships
The database role membership entries that should be checked ON are:
ams_group
db_ddladmin
db_owner
db_securityadmin
public
regadmin
service_desk_admin_group
service_desk_ro_group
workflow_admin_group
Please review AHD50060:Database check FAILED - sql_check_db -c Exit Code 99: Possible Causes for additional causes.
If DB settings are working correctly, the sql_check_db command should return with a result like this:
C:\PROGRA~2\CA\SERVIC~1>sql_check_db -c
SUCCESS - pri table exists, and has 6 rows
DB_OK
SDM does not have awareness of any changes that are made on the DB server and so must be updated via pdm_configure if the mdbadmin password is changed.
Older Service Desk implementations may be using the "ServiceDesk" user instead of the "mdbadmin" user.  Please check for the "ServiceDesk" user if the given user is applicable.
The SDM install's NX.env will list who the DB user and the MDB owner userid is defined as, with entries such as this:
@NX_DB_USERID=mdbadmin
@NX_MDB_OWNER=mdbadmin
