AXA to APM drill down does not work when the universe context is not set correctly
Article ID: 228238
CA Application Performance Management (APM / Wily / Introscope)
In APM, if a universe is set as "Universe A" and in AXA when drill down link is selected where the app data resides in "Universe B", then the link that gets constructed from AXA does not carry the Universe context and always goes to the last worked on universe (Ex: Universe A)
This is a fundamental issue where AXA to APM drill down does not work for all applications that are instrumented with AXA to APM
Release : 20.2
Component : Integration with APM
Fixed in AXA 21.6 HF 2
