Symantec Protection Engine for SharePoint Services (SPSS) Registration Fails with Error Code : 4198
Error message that appears while registering:
Errors were found on the page. The destination server did not answer inside of a timeout frame. Error ID : 4168
Error in SPSS System log:
spss+"-1", "Error", Cannot connect to host or IP Address. the requested address is not valid......
Possible reasons:
Note : Even if the service is running, restart it and check if it stays started.
Release : 6.1.0
Component : NA
Restarted the SPSS service and tried registering, successful.
The SPSS Service was in running state.
Even if the SPSS service is started and running, restart it and try registering.
