Sample rate for QOS_POWER_STATE Metric shows incorrect value
Article ID: 228194
Updated On: 08-05-2024
 Observed QOS_POWER_STATE sample rate is 0 in the UIM SQL database and -39600 via the API.
Release : DX UIM 20.4*/23.4*
Component : UIM - DATA_ENGINE
The column order was observed to be incorrect for the QOS_POWER_STATE table in the database
Correct example
Steps done to correct
1.deactivate data engine
2. drop the qos_power_state associated RN_QOS_DATA_0884,DN,HN,BN Tables and associated QOS Definition
3. drop the partition Scheme and partition function psnRN_QOS_DATA_0884,pfnRN_QOS_DATA_0884
4. Create partitions for the qos_power_state  associated RN,HN,DN and BN tables.
5. activate data_engine.
