Ghost Solution works slowly and sometimes does not respond
Article ID: 227607
Ghost Solution Suite
Ghost solution works slow and sluggish
Error in windows event viewer:
GSS 3.x
Windows Event viewer logs are full of scan Errors from McAfee or other Antivirus software
Cisco antivirus was also installed on server and endpoints
Issue is resolved by Disabling the antiviruses.
Upgrading to the latest version is also helpful, but again the antivirus should be disabled before proceeding with the upgrade.
