ALERT: Some images may not load properly within the Knowledge Base Article. If you see a broken image, please right-click and select 'Open image in a new tab'. We apologize for this inconvenience.
Need help in purging databases for Pathfinder tables- Exception in thread Pathfinder transaction cleaner
Article ID: 226043
Service Virtualization
Need help to purge out  Pathfinder Agent Tables.
All report cleaning properties are default values, we haven't specifically enabled any custom settings.
Current DB disc space snapshot:
Directory of S:\MOUNTS\DBDATA\MSSQL12
09/05/2021  02:16 AM   300,178,931,712 DevTestRegistry17_Func.mdf
09/05/2021  02:16 AM     4,577,034,240 DevTestRegistry18_Func.mdf
09/05/2021  02:16 AM     1,110,441,984 DevTestRegistry19_Func.mdf
We found out that  these tables have obsolete Data.
LISA_FRAME_DATA
LISA_TRANSACTION_FRAME
LISA_FRAME_FLAGS
LISA_TRANSACTION_INFO
 Exception in thread "Pathfinder transaction cleaner" java.lang.OutOfMemoryError: Java heap space
2021-10-11 20:31:57,949Z (13:31) [Pathfinder transaction cleaner] ERROR System.err                     -  at java.util.Arrays.copyOf(Arrays.java:3332)
   The PF Cleaner component has a defect
Release : 10.5.1
Component : DevTest Registry
This is a known issue. Please request  'patch_DE485659_10.5.0_GA.jar'   when opening a ticket
