Problem Integration between UIM/Spectrum/SOI
Article ID: 225579
CA Service Operations Insight (SOI)
There is some restriction in the correlation of two records, one of the Router class and the other of the GenericIPDevice class. The same equipment that is in Spectrum as Router, is in UIM as GenericIPDevice, and when sent to SOI the CI correlation is not done.
Is the problem really related to Class?
I did some tests, below is updated.
It seems to me to be related to the Class.
###Current data
Spectrum                   Router
UIM                            GenericIPDevice
Correlation: Does not occur
###Changing in Spectrum from Router to SNMP, in SOI it appears as GenericIPDevice - correlation occurs
Spectrum   GenericIPDevice
UIM           GenericIPDevice
Correlation: Occurs
###Sending a record via Universal Connector of GenericIPDevice class correlates with UIM record
Spectrum Router
UIM           GenericIPDevice
UC             GenericIPDevice
Correlation: Occurs between UIM and UC. Spectrum's registry stands alone.
Spectrum       Router
UIM                GenericIPDevice
UC                  Router
Correlation: Occurs between Spectrum and UC. UIM registration stands alone.
Release : 4.2
Component : Service Operations Insight (SOI) Manager
SOI will not correlate between Router and GenericIPDevice.
It will correlate between ComputerSystem and GenericIP Device.
