Javelin gzip compression settings (Speed vs Compression) GZipCompressFileActivity
Article ID: 225568
CA Test Data Manager (Data Finder / Grid Tools)
A comparison between Windows compression and Javelin gzip and Windows did better compression.
10/05/2021  02:35 PM     5,977,552,815  File000000.END.gz
09/01/2021  10:21 AM     5,308,371,114  File000000.END.zip
 Are either options used underneath the covers?
-1, --fast        compress faster  -9, --best        compress better
Javelin Version 4.9.161
Release : 4.9.1
Component : Javelin
N/A
TDM uses GZipStream(Stream stream, CompressionMode mode); which means the default is to compress fast.
Please be aware that the new FDM version (4.9.201.0 and later) includes an embedded jre rather than run a jre installer.  This will allow customers to use different jre versions that will not impact on FDM.
