Secondary hub install completed but hub turns red and robot doesn't show up
Article ID: 224743
DX Unified Infrastructure Management (Nimsoft / UIM) Unified Infrastructure Management for Mainframe CA Unified Infrastructure Management SaaS (Nimsoft / UIM)
Deploying a new secondary hub. Install finishes via nimldr (including tunnel), it shows up in IM, setup attach/get queues, check the hub that the attach/get queues & tunnel are associated with and they show connected. The hub eventually goes red and the robot doesn't show up in IM and in Admin Console it shows offline.
Release : 20.3
Component : UIM - HUB
- VMs had firewalld running on them that was blocking the UIM hub / robot traffic.
Firewall exceptions/rules.
