ALERT: Some images may not load properly within the Knowledge Base Article. If you see a broken image, please right-click and select 'Open image in a new tab'. We apologize for this inconvenience.
Certificate issue on MAC while using proxySG
Article ID: 224582
ProxySG Software - SGOS
On MAC OS system, getting NET::ERR_CERT_WEAK_KEY error for multiple sites.
ProxySG emulate certificate size less the 2048
ProxySG was SSL interception enabled.
As per Apple updated documentation below 2048 key size is needed.
 https://support.apple.com/en-us/HT210176
In proxy, we can force 2048 key size with the below command.
proxy#(config ssl)proxy force-emulated-cert-keysize 2048
Also, we need to clear the certificate cache using the command
ProxySG#(config ssl)clear-certificate-cache
and then reboot the MAC to clear any cache it has.
