ALERT: Some images may not load properly within the Knowledge Base Article. If you see a broken image, please right-click and select 'Open image in a new tab'. We apologize for this inconvenience.
Problem with Installing RA FTP Agents during DB Load
Article ID: 223512
CA Automic Workload Automation - Automation Engine
We are trying to install and setup the RA FTP agent.
We are trying to import FtpAgent_solution.jar via ucybdbldg. We have a problem and error.  Also we try upload FtpAgent_solution.jar version 4.0.1 and 4.1.0
Log from utility/temp is added, this is the error:
20210908/131208.850 - U00038157 Generating RA connection 'FTPCONNECTION'.
20210908/131208.850 - U00038150 A database error occurred:  'SQLExecDirect', 'ERROR   ', '01000', 'The statement has been terminated.'.
20210908/131208.850 - U00038067 ABORTING due to error!
CONN.FTPAGENT.FTPCONNECTION already existed in client 0
Release : 12.3
Component :
Solution:
If this happens remove CONN.FTPAGENT.FTPCONNECTION from client 0 and run the DB Load again.
