We find that there are some jobs in "Job Template For Process Engine" state in Home -> Reports and Jobs -> Jobs -> Scheduled Jobs page. Is this expected?
The job with the "Job Template For Process Engine" status has been set to run through a process
This is expected if you run a job through a process. Nothing to worry about
That job called by the process will be seen with the status: "Job Template For Process Engine"
