This is an article documenting a known defect which impacts the filtering and sorting capabilities within the MCS UI, Operator Console MCS tab.
Symptoms of issues:
1. Filter - When using a filter, it's only applied to the "profile name" and not the "template".
2. Sorting - If you sort by "profile name" it works as expected. Sorting by "template" does not order correctly.
Product defect
Release : 20.3
Component : UIM OPERATOR CONSOLE - MCS UI
UIM 20.3.3 July Patch
This issue is fixed and will be part of the upcoming monthly patch release (ETA 7th - 10th Sept).
