ALERT: Some images may not load properly within the Knowledge Base Article. If you see a broken image, please right-click and select 'Open image in a new tab'. We apologize for this inconvenience.
Automation Engine compatibility on Windows with Unix PostGreSQL DB
Article ID: 222848
CA Automic Workload Automation - Automation Engine
Is it possible to use an AE on a Windows system with a PostGreSQL DB installed on a Unix system ?
Do we need a DB Client on the Windows system ?
Release : 12.3
Component :
Yes, AE on Windows can communicate with PostGreSQL on Unix.
You need to install a Client on the Windows system compatible with PostGre.
