Post Method not supported for setting up new password after loading SampleTemplates.zip
Article ID: 222382
CA API Developer Portal
API Portal provides a set of templates for each of the core API Portal pages that you want to customize.
The templates are available in SampleTemplates.zip file that you have to download from Content Management, Upload Page Bundles section.
After loading the pages included in SampleTemplates.zip following the documentation steps in Customize Core Pages, a user cannot reset the password from API Portal.
The request fails stating that POST is not supported.
API PORTAL
An issue in the Reset Password sample page prevents the Reset Password function
  1. Download the attached SampleTemplates_NEW.zip and extract the zip file.
  2. Replace your local Reset Password page with the file from the zip extract.
  3. Customize any other pages that are required using the steps identified under Start Customizing section and upload to API Portal.
Though we are providing this fix for the Sample Templates, please note that as part of API Portal 5.0, we have announced the deprecation of Custom Pages and Custom Pages resources in the Portal APIs(PAPI).
For more information, see release notes for API Portal.
Customers that would like to include custom pages are advised to transition to API Hub, available in Portal 5.0.
1629968871038__SampleTemplates_NEW.zip get_app
