ALERT: Some images may not load properly within the Knowledge Base Article. If you see a broken image, please right-click and select 'Open image in a new tab'. We apologize for this inconvenience.
Need help with using REST UI to put CI in maintenance
Article ID: 222349
CA Service Operations Insight (SOI)
Need help with using REST UI to put CI in maintenance.
Would like a procedure that would get the InstanceID from a command.
Release : 4.2
Component : Service Operations Insight (SOI) Manager
Use command to export all CIs belonging to a service
WSSSAServiceCmdV2 -hlocalhost:7090 -usamuser -p"EFbJeXR3zLsi9aPfOQ9FzRVOPPEUwCGxCWUFTNF4kxKD" -aExport -s"Service:servicename,WSMan New Service" -fc:/myServiceExport.xml
Here are the 3 regex you will need for Notepad+++ to search the Label, MDRElementID, ci_namespace values
Regular expression to select value for Label
(?<=<Label>)(.*)(?=</Label>)
Regular expression to select value for MDRElementID
(?<=<Mdrelementid>)([0-9A-Za-z]+[^:])(?=</Mdrelementid>)
Regular expression to select value for ssa_ci_namespace_map_id
(?<=>)(.*)(?=</ssa_ci_namespace_map_id>)
