ALERT: Some images may not load properly within the Knowledge Base Article. If you see a broken image, please right-click and select 'Open image in a new tab'. We apologize for this inconvenience.
Problems with SEP Mobile CORPORATE WI-FI PROTECTION
Article ID: 222114
Endpoint Protection Mobile
SEP Mobile is not detecting Hotspot Vendor. This is causing an issue with legitimate Hotspots which are detected as malicious.
Below an example of the symptom.
Symantec is aware about this issue and already working to provide a fix
