Container Gateway: Connection issues with Policy Manager
Article ID: 221887
Updated On: 10-19-2023
CA API Gateway
We are working to setup environment with container gateway and having issue to connect from policy manager with below details.
  • Our pods are up and running on EKS cluster
  • Trying to connect from policy manager using the external ip
  • Having below issue: i was able to connect but failed with same timeout issue immediately.
  • Logs from pods
{"package":"com.l7tech.server.admin.AdminSessionManager","level":"WARNING","log":{"client-ip":"<IP_Address>","message":"Admin session/cookie not found: \u003cnot shown\u003e.","listen-port":"Default HTTPS (8443)"},"time":"2021-07-30T20:17:55.002+0000"}
Release : 10.0
Component : API GATEWAY
Gateway in Microsoft azure environment as a container (cloud/elK) deployment with multiple gateway pods PODS
Problem Policy manager(PM) access:  When authentication occurs it’s request is processed by one POD then goes to the next POD.  In this flow the session for PM is not known.  Results:   “Gateway Inactivity session timeout has been reached”
This type of deployment is not tested/certified, however we do provide best effort
https://techdocs.broadcom.com/us/en/ca-enterprise-software/layer7-api-management/api-gateway/congw-10-1/install-configure-upgrade/differences-between-the-container-gateway-and-appliance-gateway.html
Workaround
For the load balancer to handle the sticky session probably needs to add the following, so it will always route traffic from a particular IP to a pod.
 sessionAffinity: ClientIP
  sessionAffinityConfig:
    clientIP:
      timeoutSeconds: 10800
