logmon not starting - max restarts - bind error 98
Article ID: 220616
DX Infrastructure Management
logmon probe will not start, and eventually goes red/reports max restarts.
Log shows the following over and over (the port may differ):
Mar  9 18:20:27:721 [139898666776352] logmon: sockServer: next available port is 48012
Mar  9 18:20:27:721 [139898666776352] logmon: sockServer: bind failed 98
Mar  9 18:20:27:721 [139898666776352] logmon: nimSession - failed to create server session on port 0, error code 98
Mar  9 18:20:27:721 [139898666776352] logmon: nimSession failed
caused by some conflict on the given port at the OS level
Release : 20.3
Component : UIM LOGMON
resolution:
edit "controller" raw configure  (robot.cfg)
<controller> section
set:
first_probe_port = 480xx
where 480xx is one higher than the port reported in the error message.
So if the error says "unable to bind to port 48012", set first_probe_port = 48013
