Problem with "head -n 1" when using /dev/urandom within function during Unix Job execution.
The issue was reproduced with below line.
cat /dev/urandom | tr -dc 'a-zA-Z0-9' | fold -w 13 | head -n 1
Release : 12.2, 12.3
Component : AUTOMATION ENGINE
Sub-Component: Linux Agent
This problem is related to the feature of linux where program "head -n 1" ends, but the rest ignores the signal because they are running in an non-interactive shell. More information can be found here: https://stackoverflow.com/questions/26461014/bash-head-tail-behavior-with-bash-script
The workaround is to change/rearrange your script that it could use below example:
1. The issue was reproduced with below line:
To go around this we created a shell script random.sh with the following content:
#!/bin/bash
{ head -n 1; kill "$!"; }< <(exec cat /dev/urandom | tr -dc 'a-zA-Z0-9' | fold -w 13)
2. Another workaround is to use an older agent, from 12.0 - the last SP preferred.
Fix planned in future releases, no date known yet
