Is it possble to monitor Power9 frames using UIM, e.g. with the ibmvm probe?
Release : 20.3
Component : UIM - IBMVM
ibmvm probe can monitor the IBM Power7+ (7.9 through 8.3) only.
If these devices are exposed to SNMP you might be able to use snmpcollector or snmpget for generic collection, otherwise this would be considered an enhancement request.
https://knowledge.broadcom.com/external/article/12135/how-to-raise-an-enhancement-request-for.html
