When defining the SSL Context for Kafka Assets defined the Trust Store and Key Store which passwords defined as DevTest Property Reference style like below:
However, the verification for SSL Context level got the error messages like below:
Verifying Asset
Autopopulated Trust Store with PDS_PAYMENTS_TRUSTSTORE (Trust Manager)
Autopopulated Key Store with [email protected]_PAYMENTS_KEYSTORE (Key Manager)
Creating SSL Context with protocol: TLSv1.2
Creating Key Store with type: jks
Loading Key Store <cert file name>
Initializing Key Store
Error: Error accessing key null + in keystore: Password must not be null
If the password definitions in Trust and Key store are defined with "Normal editor", then this problem does not happen.
Release : 10.6
Component : CA Service Virtualization
This is a known problem in DevTest 10.6.
There are workarounds of this problem.
