What is the difference between a WIP Reversal and a WIP Transfer and WIP Adjustment? What do the 'Reverse' and 'Transfer' buttons on the Create WIP Adjustment page?
What is the effect of each function?
Release: All Supported
Component: Clarity PPM Financial Management
WIP Reversal
The WIP Reversal is a function that allows the transaction to be removed completely from the financial module. When a reversal occurs, the record remains in the PPA_WIP table denoted by the status = 2, however the transaction cannot be seen from the UI, i.e. the transaction cannot be searchable from the either the Create WIP Adjustment page nor the Posted Transactions Review portlet.
The TRANSNO and APPLYTO will have the same TRANSNO.
After a reversal takes place on the financial side, the approved reversal must then be removed from the project side.
The reversal amount is removed by running the Import Financial Actuals job.
If a WIP reversal for a financial transaction that originated from a timesheet, there will be a discrepancy between the timesheet transaction vs the financial transactions.
To reverse or remove timesheet entries:
WIP Transfer:
The WIP Transfer is a function that allows the transfer of a transaction from one project / task to another project / task combination.
If the originating transaction comes from a voucher transaction entry, use this Transfer button.
The transferred amount is updated on both projects when the Import Financial Actuals job executes.
To use this feature, you have to follow specific steps to transfer to another task within the same project or to transfer another project/task combination. The destination project must have the destination Resource assigned to the destination task before performing the transfer action. If the transaction is selected for transfer and the specified filtering is not performed to show the transaction, the WIP transfer action will not be successful.
WIP Adjustment:
If you only need to adjust the transaction and not reverse or transfer it, click on the Transaction Date to open the transaction and create the adjustment.
WIP Adjustment and WIP Transfer create a new transaction and can be tracked back to the original transaction in the APPLYTO field in the database. To create a WIP Adjustment enter the desired values (including the quantity) not the delta. For example, if the original quantity was 10 and the quantity should have been 6, enter 6 in the quantity on the adjustment. The system will calculate the delta when posting the adjustment transaction.
