PDS-Plex DPI resolution problems after upgrading
Article ID: 217361
CA Plex
After upgrading Plex from 7.2 to 7.2.1 004. Platforms: Winc-AS400
scaling problems in 721 generated applications. Panels appear smaller in 721 compared to 72 making them hard to see.
Does it make a difference to respect DPI/resolution issues to upgrade from 004 to 005?
Release: 7.2.1 004
Component : CA Plex
There are few DPI issues resolved after PTF build 003. upgrading to the latest build 005 will resolve the issue
For built applications,  re-create EXE for top-level function
