data_engine probe is red and down and throws max restarts in the log
Article ID: 217186
DX Unified Infrastructure Management (Nimsoft / UIM) Unified Infrastructure Management for Mainframe CA Unified Infrastructure Management SaaS (Nimsoft / UIM)
This morning it was found that the data_engine probe was red and not responding to restarts.  Logs shows "Max .restarts" entry.
Java version is updated and the login name has not changed.
data_engine.log errors:
Jun 11 11:05:35:249 [1340] 0 de: [main] Open - 2 errors
Jun 11 11:05:35:250 [1340] 0 de: (1) Open [Microsoft SQL Server Native Client 11.0] Cannot open database "UIM" requested by the login. The login failed.
Jun 11 11:05:35:250 [1340] 0 de: (2) Open [Microsoft SQL Server Native Client 11.0] Login failed for user 'xxx'.
Jun 11 11:05:35:250 [1340] 0 de: COM Error [0x80004005] Unspecified error - [Microsoft SQL Server Native Client 11.0] Cannot open database "UIM" requested by the login. The login failed.
Jun 11 11:05:35:250 [1340] 0 de: Unable to connect to database. so exiting
Jun 11 11:05:35:250 [1340] 3 de: Database_global_lock LOCK
Jun 11 11:05:35:250 [1340] 3 de: Database_global_lock UNLOCK
Jun 11 11:05:35:250 [1340] 0 de: Database library - program is exiting through exit()...
Jun 11 11:05:35:250 [1340] 3 de: Database library unloaded
Jun 11 11:05:35:250 [1340] 3 de: Database_global_lock DESTROY LOCK
Jun 11 11:05:35:250 [1340] 5 de: lockStatisticsFile DESTROY LOCK
Jun 11 11:05:35:250 [1340] 5 de: lockQueueName DESTROY LOCK
Jun 11 11:05:35:250 [1340] 3 de: Copy Snapshot DESTROY LOCK
Jun 11 11:05:35:250 [1340] 5 de: lockConvertState DESTROY LOCK
Jun 11 11:05:36:190 [1716] Controller: Max. restarts reached for probe 'data_engine' (command = data_engine.exe)
  • Release: 20.3 or higher
  • Component: UIM OPERATOR CONSOLE - METRIC VIEWER
  • Something must have changed in the cluster/cluster VIP/configuration.
There was nothing wrong in the data_engine probe.
Changed the data_engine configuration to a specific node in the cluster, by using one of the cluster IP addresses, then the data_engine could successfully connect without issue.
We then made sure all of the other probes on the Primary hub were started.
