Unable to find the device model and vendor information in OpenAPI
Where in REST can you find the device model and vendor information?
All supported releases
As of 20.2.10, the OpenAPI does not expose the device model and vendor information but this information can be seen in the REST API under: http://daHostname:8581/rest/devices/manageable/device_item_id.
For example:
