The out of box Portlet titled Project Life Cycle Review is not honoring the filter selection for methodology (aka Template). We have projects that were created using Templates and our intent is to use this portlet to determine progress for projects that were created using specific templates. The content shows up only when the template is set to All in the filter. Following Screen image reflects list of projects created using templates
Following image reflects no content when the portlet is run with the filter set to desired Template
Release : All
Component : CA PPM SAAS PROJECT MANAGEMENT
