This technical article documents a known defect with the OC Metric Viewer.
Symptoms of Problem:
Steps to reproduce:
Checking the network tab developer tools you can see the OC is logging the network call "named-views" as status: 500, errorCode: "500", example of response below:
{"status":500,"errorCode":"500","errorMsg":"Error creating view. Metric view with same name already exists for the combination of account and username.","errorDetail":null,"timestamp":{"nano":61000000,"epochSecond":1620706596}}
Release : 20.3
Component : UIM OPERATOR CONSOLE - METRIC VIEWER
Product defect / bug.
This defect has been replicated internally and the UIM OC engineering team has confirmed it will be fixed as part of the next Hotfix / Patch which is scheduled mid-July 2021 (Tentative).
Any questions or concerns, please contact Broadcom Technical Support and reference this article (Article Id: 216702).
Please be aware there is a separate defect related to the Metric Viewer which has already been resolved via UIM 20.3.3 HF1 (June Patch), more details can be found in the below article.
Article ID: 216556
UIM 20.3.3 HF1 edit metric fails: "This view name already exists. Please create a different view name"
https://knowledge.broadcom.com/external/article?articleId=216556
