All devices in NFA are displaying current flow, but none of the interfaces are displaying a currently last flow date. The current last flow dates are all around the same timestamp.
You may also see that there are no Pump logs or no recent Pump logs.
Component : NQRPTA - REPORTERANALYZER
NFA Console Pump service has hung.
Check the NFA Console logs for the pump logs (PumpLogYYY-MM-DD.log). Look for a timestamp of the pump logs. It should be updated frequently (every few minutes at least). If there are no pump logs or the latest log timestamp is old, it is likely that the pump service is hung and needs to be restarted. Just do the following:
