DT656I Errors When Using Detector SQL Table Activity Display
Article ID: 215652
Updated On: 12-06-2023
Detector for DB2 for z/OS Database Management for DB2 for z/OS - Performance Suite
When attempting to use the SQL Table Activity Display to show tables, indexes, and statistics for the SQL calls that are selected in the Plan SQL Display.
When the option is selected, the following information message:
DT656I: No table or index has been referenced by statement viewed
Documentation points out that Subsystem Analyzer for Db2 for z/OS (PSA) needs to be installed to be able to use this function. What is needed in order to
view the plan SQL and SQL table activity?
Will additional tables need to be created in order to use this feature?
Component : Detector for DB2 for z/OS
DT656I is an indication that Subsystem Analyzer in not installed and and active collection executing.
