Problem for Importing the LDAP setting information from required xml files In DevTest
Article ID: 215389
Service Virtualization
When trying to import the LDAP authentication information to DevTest environment based on the manual below:
https://techdocs.broadcom.com/us/en/ca-enterprise-software/devops/devtest-solutions/10-6/installing/preparing-your-devtest-upgrade/upgrading-the-authentication-component.html
but the User Federation part in the Identity and Access Manager displays nothing.
And there is not a file named "export2iam" in LISA_HOME directory/folder.
Release : 10.6
Component : CA Service Virtualization
The file name "export2iam"  is mistake in the manual. The correct file name is ".export2iam".
The location for the required .xml files(authentication-providers.xml and ldap-mappings.xml) is not clear in the manual, the location is LISA_HOME.
These steps solved the problem and the User Federation part in the Identity and Access Manager displays information for LDAP.
  1. Stopping registry
  2. Deleting ".export2iam" file in LISA_HOME directory/folder
  3. Locating required .xml files to LISA_HOME
  4. Starting registry
