CTRL-ALT-DEL does not work on Remote Control Host
Article ID: 21517
Updated On: 11-04-2022
CA Client Automation - IT Client Manager CA Client Automation CA Client Automation - Remote Control
When taking control of a Remote Control host machine, the CTRL+ALT+DEL key sequence is sent in order to log on.
But nothing happens. The logon screen does not appear.
In the logs TRC_URC_HOST_0.log or TRC_URC_UTILCMD_0.log following lines are displayed:
     UTILCMD |RCOS |000000|INFO | CRCLoginDesktop::DoCtrlAltDel: doing Ctrl-Alt-Del
     Ctrl-Alt-Del is correctly received by the Host machine but nothing is done.
     CA Client Automation - All Versions
     All supported Windows Operating Systems
This problem happens if the "Disable or enable software Secure Attention Sequence" windows logon Policy is set to  "None" or "Services"
If the "Disable or enable software Secure Attention Sequence" windows logon Policy is not defined or set to "Ease of Access Applications" or "Services and Ease of Access applications", sending of CTRL+ALT+DEL works
Check if the following registry key exists
     HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System\SoftwareSASGeneration
If it exists and is set to 0 (None) or 1 (Services)
then do the following:
  1. Open gpedit.msc
  2. Select Computer Configuration\Administrative Templates\Windows Components/Windows Logon Options
  3. Change "Disable or enable software Secure Attention Sequence" from Enabled to Not Configured or to "Ease of Access Applications" or "Services and Ease of Access applications"
This also could be done in command line with reg.exe
Example :
This command sets the value 3 for SoftwareSASGeneration which is "Services and Ease of Access applications"
reg.exe ADD HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System /v SoftwareSASGeneration /t REG_DWORD /d 3 /f
